Here's a run-down of my Saturday arvo....
1. My Gas Gas, leaking rear tyre.
Took the wheel to my local mechanics the other day and got him to break the bead. No way I was able to do it at home.
Bought a new tube (valve had torn away from tube, thus the leak). Do you think I could even fit that? No chance! Ending up pinching the tube and putting a hole in it. Threw it into the car in disgust and took it to a local motorcycle place who changed it on the spot. New tube and job done for $30.
Well, almost job done...
One side of the tyre hadn't seated, so out with the compressor and inflate, inflate, inflate. Lubed it up with some slippery stuff, then took it up to 90 psi
. Not seating. So I figured "I've come this far" and switched on the compressor again - 2 seconds later it popped into place. One job done!
2. Cleaning 3x chains after a muddy trial at Emu Flat the other week. I tell you, mud is nasty stuff. The chains were clagged, and that's *after* they were high-pressure-cleaned. Out with the wire brush, then a good soaking in some degreaser. We'll see how they go.
3. Sam's Rev 80 running like a dog after a water crossing. Pulled the air filter out for a clean (OK) and nothing in the airbox. Perhaps it dried up. Pulled the carby off, and stripped/cleaned it. Some minor blockage in one jet. All back together. Put a new plug in as well. Starts and runs beautifully now. Two jobs done.
4. Rev 80, dripping oil from the muffler, so decided to repack it. Old packing oil-soaked and 'orrible. Repacked it without drama, rivetted back together, and all good. Three jobs done.
5. Found a broken spoke on the Rev 80 whilst cleaning it. After the episode with the GG tyre, I'll be dropping this one off at the bike shop and collecting it the next day. Not worth the headaches!
Still a few more tasks to do, but at least I got Sam's bike more-or-less done. Three bikes equals a lot of hours.
Someone tell me it's all worth it!
I can tell you the beer tasted great tonight.
....it's fun on the forth attempt too
