Sherco triple clamp help
Posted: Sun Oct 05, 2008 3:35 pm
Hey,
so I got my new lower triple clamp (thankyou Don @ moto central) got some bearings for it, put it all back together but I think I have a problem. The stem (on the lower triple clamp) that runs up thru the headset inside the bearings is a fraction shorter than the old one.
When I tightened the nut up ontop of the stem, only the bottom half of the nut picks up the thread on the stem.
is this bad?
Both top and bottom bearings are seated correctly, and I re-used the aluminium washer that sits below the lower bearing.
Thanks,
Tom.
is this bad?
Thanks,
Tom.
