what oil for my beta 250 2t
mickd
Post by mickd »
hi all
please can you help me with this one!!! ive been told to put castrol mtx in the beta for the eng/gearbox but this cant be right!!!its says on the bottle 75/90 is this too thick? i was thinking on the lines of 10/40 or 20/40 fully syn
or does the beta have a dry clutch
beta 250 2t 07
what would you put in
regards mickd
motostar99
Club: LRMTC, NDMC, SQTA
Bike: 2002 Sherco 290
Re: what oil for my beta 250 2t
Post by motostar99 »
I'd be thinking that was too thick..
I use 10w40, it's also what's recommended in the Sherco manual and I'd be guessing your bike would be pretty similar..
Nic 8)
motostar99
http://metalmarkers.org/sitebuildercont ... s/rev3.pdf
Go to page 48 in this, it's a guide for the 2002 Beta. Has the recommended oils from them there. I don't think they've changed too much between then and yours?
Nic 8)
2IC
2IC
Bike: Beta EVO
Post by PA »
Transmission Oil. 550ml Bardahl Gearbox 20W40 from the owners manual.
Stork955
Post by Stork955 »
Gday all, gear oils and engine oils use a different "weight" system. 80/90 gear oil is pretty close to 10/40 engine oil in "thickness". I assume that MTX is a transmission oil so it would be OK. Personally I use Dexron 3 Auto transmission fluid in all my 2 stroke gearboxes. Its the best for clutches.
Stork :TAS:
kembro
Bike: Beta Rev3, DRZ
Post by kembro »
Shell Advanced gear oil 10w is what David from Beta Racing recommended. Thanks for the link Motostar99.
