Sherco 2010, a totally new motorcycle.
Sherco Qld
Dealer
Dealer
Post by Sherco Qld »
Sherco finishes presenting/displaying trial motorcycle 2010, a totally new model with spectacular changes that without a doubt liked to the unconditional ones of the mark. At the moment, Sherco advances a photo in that to a series of darkening filters and treatment of the color have been applied, being this result.
At technical level the most important change is the interchange of location of the filter of the air and the gas tank. The motor remains invariable aside from the small adjustments that can be realised
Characteristics trial Sherco 2010
- New chassis realised in section of round tube.
- General Redistribution of weights and displacement of the center of gravity downwards, favoring a new center of rotation of masses.
- Filter house in the classic position of the deposit contributing and guaranteeing the fresh air intake, at the same time as it increases the fording capability in zones of water, arranges besides an immediate accessibility. Avoiding therefore the intervention in other parts of the vehicle.
- I deposit in Ergal in the classic position of the filter house, equipped with a system anti internal mumbling, with integrated gasoline pump.
- New set escape of greater yield thanks to its new design, inner, as as much outer.
- New Ceriani bracket, with treatment in the bars of ‘ micro crom ’ that favors the sliding in a 15% with respect to the conventional black bars, has besides a system of inner pumping in aluminum new conception, conferring to him it yet a reduction of weight of more than 0,250 kilo.
- Cushioning adapted inner defective buttock equipped with a new wharf and different from this new and revolutionary geometries.
- A new brace of butt able to act a multiple as: to give to rigidiza major to the chassis, avoiding vibrations and organizing the electrical components.
- New protector case with function anti much more slight backward movement
- Totally new, narrower and light Body
- New subtle and rigid front mudguard, with puenta but
- New back mudguard more width in its high part
- Filter house superior
- New Plate of light with double optics of leds
- Protective lateral symmetrical adapted to the new design
- New narrower radiator and in the form of Or that a high performance in the refrigeration provides.
Information: Sherco Motorcycle
Sherco's new 2010 trials bike will be going into production in september,expect the new trials bike in Australia in late December
Sherco Qld
0408716428
www.Sherco-Qld.com.au
Re: Sherco 2010, a totally new motorcycle.
Hi Scott,
Am I right in assuming this was in Spanish and you have googled the translation to English? Do you understand the translation? I can make out bits and pieces!!! Is there a way of simplifying what they are saying? Any help would be appreciated and I assume I am not the only one interested!
Thank you
hugo
Post by hugo »
Greg Harding wrote:Hi Scott,
Thank you
Greg, you might want to check this poster from the UK importer on which there is a proper translation at the bottom:
http://www.malcolmrathmellsport.com/assets/images/2010newbike.002copy.jpg
