TY175 intake stub RD350
uk steve
Bike: ty 175
Post by uk steve »
hi again,i got hold of a rd 350 air cooled intake rubber stub read block & spacer will this make any change to performance? :roll:
if my vans a rocking dont bother knocking! (dont laugh your daughter might be inside) bikes are born to be ridden
OKOAustralia
Bike: Any I can find
Re: TY175 intake stub RD350
Post by OKOAustralia »
Steve
If you're not worried about originality, then an OKO 3020 flatslide is what you need.
Otherwise, we recommend installing an OKO 3000. Have fit/sold a number of these for the TY175 and the results are terrific.
No need to change the existing manifold for either of these carbs.
OKO Australia
http://www.oko-australia.com.au
Tee-Why
Post by Tee-Why »
Steve, beware that the RD one is centrally locating the carb, so it will be closer to the exhaust pipe - can be an issue on hot warm days to vapourising fuel in the carby. The original rubber is offset for this reason apart from clearing the frame tube coming down from under the tank. The combination of spacer and the RD inlet may cause a slight clearance issue to frame.
I tried a spacer on mine, got a heap more low end, but killed the midrange, pulled it out for that reason.
Starky
Bike: TY175, TY250
Post by Starky »
Starky
