A little puzzle for you to think about .....
.... On Sunday, after completing the last section of the day and on the short commute back to camp, the bike gave a splutter and fart, ran fine for another 10 seconds and promptly died. I coasted to the ute thinking nothing more than I had run out of go juice..... that's exactly what it felt like ..... no fuel.
Got home that night and gave the bike a quick hose down to get the bulk of the muck off and parked it. Next day, wheeled it out and gave it a scrub with truck wash and a quick gernie off ensuring not to direct and high pressure spray into the delicate areas.
Once dry and greased I flicked the fuel tap onto reserve and gave the bike a kick, nothing, another kick, almost, another, nothing. I thought perhaps the reserve circuit in the fuel tap was blocked so I proceeded to put a litre or so of fuel in the tank, to my surprise it nearly overflowed...... strange, I thought it was a 3 lt tank? You were right Peter, I shouldn't have run out of fuel considering I filled up at lunch. Anyway, with the tap in the 'on' position I kicked a few (20) times, nothing.
Sorry for the lengthy tale so far, but it helps to know the full story
So I started eliminating possible causes.
Air filter clean but a little moisture in the bottom of airbox, probably from cleaning. So I was getting air.
Drained carbie bowl, a couple of drops of water in drain plug, no real drama. Turned on fuel to make sure fuel was getting to bowl, all OK.
Spark, checked plug (black and not really wet) spark appeared a little weak and wasn't consistently arcing from electrode to earth tip, jumped about a bit. I put that down to my girly arms trying to crank the bike over and watch the plug at the same time.
Compression, present.
So after all of that, the old girl still won't start. My final thoughts are that I possibly have a blocked jet somewhere in the carbie. Any way to test that theory without pulling the carb out and physically looking? Any other ideas on what may be going on?
Your thoughts are most appreciated....
Will
