tlr200 stripping of road gear
phillridge
Club: n/a
Bike: n/a
Post by phillridge »
Hi all
As I have had my TLR200 for a little while now I would like to strip away the weighty stuff, indicators, tail light and headlight assembly. I have seen some posts , maybe from Andy, regarding the wiring tricks associated with removal of the electricals, leaving a kill switch and ignition system. But the one thing that has me stumped is the plugging of the hole in the front hub when I remove the speedo cable. Any clues or tips out there!
Merry Christmas
Phillridge
sharvie
Re: tlr200 stripping of road gear
Post by sharvie »
Hi Phil,
Black silicone is the go, not that glamorous, it works though.
Steve
Sharvie ~ Maitland NSW
Andy
Post by Andy »
............ agreed but with a slight variation. So as not to gum up the hole too much I went to the local hardware store and bought a small plastic cap that more or less fits the hole. Apply a little silicone and pop it in the hole, looks a bit better than just a silicone bung but does the same thing.
Andy
phillridge
Club: n/a
Bike: n/a
Hi lads
Thanks for the practical and less than elegant solution. I was fcussed on a piece turned up on lathe to fit said hole in hub. But I do like the ablity to do the job and get right back out there. Is there anything that can't be fixed with silicon, I think not.
Best wishes and thanks.
Phillridge
2IC
2IC
Bike: Beta EVO
Post by PA »
Wine Cork. Used to work on the TY175.
PA wrote:Wine Cork. Used to work on the TY175.
But what do you do with that red fluid that is left in the bottle after you use the cork?
Starky
Bike: TY175, TY250
Post by Starky »
The black rubber bungs you use in the arse :shock: of your tinny to block the drain holes. They come in a heap of sizes and come in red as well.
Starky
phillridge
Club: n/a
Bike: n/a
Thank to all for these imaginative uses for bungs of all colours and the use there of however deviant. Perhaps I might follow the Honda colour theme and alternate between red, blue and white.
Regards and Merry Christmas
Phillridge
