81 Montesa Cota 200 Repair and Restoration
Posted: Tue Jan 24, 2012 11:47 pm
Hello everyone i'm new to the site as me and my father are repairing and eventually restoring my 81 Cota 200 and i'm probably going to need some of your wisdom!
I've had the bike for about 4 years now, and it was running fine until one day, it randomly wouldn't fire up (there's no longer a spark), and also the gears are messed up....
It's difficult for me to explain what the gears are doing and i'll give it my best at describing the problem but chances are i'll have to take it to a specialist!
right the gear lever/selector wil click up and down but i think it's going into other gears all in one click. i.e if i go up from neutral (when i can get it into neutral that is) it will select the next gear, then the lever won't spring back into the middle but will allow me to carry on going up into the next gear, and possibly the next gear after that! and it's the same when i shift back down again.
Also the kickstarter doesn't spring back to it's starting position (but i think i can fix that one).
I've got lots of pictures and i've got the bike in pieces now, i've taken the case off the side of the crankcase, so the clutch and cogs etc are all out in the open....
Please help as i have little knowledge on this engine because i've never needed to take it to work on it before.
There's also a small key slot in the stem in the side of the frame, just under the handlebars/yolkes does anyone know anything about this? I think it's some sort of steering lock which i don't have a key for.
Thankyou Luke
(I'll be copying and pasting this on other forums)
Thankyou Luke
