TY250A Outer Cases
toffejonge
Club: none
Bike: Bsa bantam
TY250A Outer Cases
Post by toffejonge »
Hi, Can anyone tell me or know if the outer castings on a TY250A engine are aluminium or Magnesium..I need to have a few deep scratches and dents welded up..
bigdog
Bike: gasgas
Re: TY250A Outer Cases
Post by bigdog »
the ally case will be heavy as compaired with mag.If filed or small drilled the mag filings will burn with a lighter or match,the filing are so light they get airborne with the slightest breeze,they will float on water. the welder can also test by welding a blob of 5% sil/ally 4043 on casting then break it off ,if it comes off easy with plyers, it will be a mag casting.Make sure its all clean as if you could eat off it! hope this helps .
Yes TY250A model cases are aluminium. The flatter shape cases that come on on B model and later models are magnesium. Both types can be welded by someone with the right skills.
toffejonge
Club: none
Bike: Bsa bantam
Thankyou for all your help in answering my enquiry..now to find a good welder in brisbane..
