Page 1 of 2
2 stroke oil
Posted: Thu Jun 27, 2013 9:59 pm
by wil15424
Hi people what's the good oil on 2 stroke oil for a 1976 TY 175???
it's probably been asked umpteen times, so now its +1 sorry.
I run castrol TTS Fully Synth in the son's yz 85 but was wondering what other options I have for the TY that's a good clean 2 stroke oil with good performance ??
Thank's in advance for info & direction on previous posts
Wil
Re: 2 stroke oil
Posted: Fri Jun 28, 2013 5:15 am
by Jon V8
That's exactly what I've been using in my TY250 since 2006, at a 50-1 ratio.It also goes in my Stihl chainsaws and strimmer. All are running well with no signs of wear or excess smoke...
Re: 2 stroke oil
Posted: Mon Jul 01, 2013 12:57 pm
by wil15424
Thanks Jon V8
Wil
Re: 2 stroke oil
Posted: Mon Jul 01, 2013 1:50 pm
by TYNSW
We maily use Motul 510 on out Ty's. Go to Sportcycles (bikecare) and ask for Andy, he rides and Denman and will give you what you need. They are located at Whitebridge
Re: 2 stroke oil
Posted: Mon Sep 02, 2013 7:23 pm
by Pmcwll
Hi there guys,just bought 02 cota 315R and have bought castrol TTS1 racing 2. Stroke fully synth,but my manual said to run the bike at 80:1 ,is the castrol oil ok for this,
Cheers Peter
Re: 2 stroke oil
Posted: Mon Sep 02, 2013 10:23 pm
Pmcwll wrote:Hi there guys,just bought 02 cota 315R and have bought castrol TTS1 racing 2. Stroke fully synth,but my manual said to run the bike at 80:1 ,is the castrol oil ok for this,
Cheers Peter
Your Honda Cota is liquid cooled so it does not see such a wide operating temperature range as with an air-cooled motor, so does not require as much oil in the fuel as an air-cooled trials bike does. TTS is a good choice if you run the motor up to operating temperature at least once a month. There are better oils for preventing bearing corrosion during long term non-use.
Re: 2 stroke oil
Posted: Tue Sep 03, 2013 6:25 am
by Pmcwll
Thanks for that David ,
Re: 2 stroke oil
Posted: Fri Sep 06, 2013 9:49 am
by Guy53
Can anybody tell me the difference ( or benifit ) between oil with Castor oïl in 2s oïl? I normaly use ``Koltz Original TechniPlate `` oil 50 to 1 in my TY TS but the last time I went to buy some, I bought `` Klotz Super Techniplate With 20% Castor Oil `` by mistake. I have heard about Castor oil for a long time, but, I realy don`t know much about it.
Re: 2 stroke oil
Posted: Fri Sep 06, 2013 8:19 pm
by Betaman
I use castor oils(Castrol A747 and Maxima 927) in my methonol burning dirt track bikes so I did experiment with castor oils in my trials bike and found a significant loss in throttle response. Not going there again
I found the best results from 100% synthetic oils.
Re: 2 stroke oil
Posted: Fri Sep 06, 2013 10:15 pm
Castor oil has very good lube properties at high temperature, but the rate of carbon buildup in the combustion zone is very high, so requires frequent removal, and it is very tenacious (I'm talking power tools to get it off). Not just on the piston crown, head and exhaust port, but it also forms in the ring grooves, which jams up the rings. It might be OK in road racing where motors get pulled apart for new rings and pistons very frequently, but on a trials bike, it would have to be the last oil most people would choose to use. I say most people, because some people enjoy working on their bike motor.
