Honda TLM260 suspension bearings
Posted: Fri Sep 06, 2013 5:16 pm
I need to replace the bearings and bushes on my TLM260 swing arm linkage
The parts I need are in the middle of the 3 bearing sets on the linkage.
The bearing is OD 23mm, ID 17mm and L 20mm
The top hat hardened sleeve that the bearing runs on is also rubbish.
This is OD 17MM, ID 12MM, overall length 29mm
Does anyone have the Honda part numbers or a source of parts, fitted to another model perhaps?
They may be the same as the earlier TLM 200, 220, 240 etc but I do not know.
Many thanks,
Matt
Many thanks,
Matt
