When installing a new throttle tube (lets say Domino plastic) is lube required and if so, what type (lithium, dry grease, etc.) would you recommend? Also I maybe totally wrong but is it possible to run them without lube at all?
Possible places to lube, maybe?
- Between the tube and the bar?
- On the inside and/or outside of the throttle wheel?
I have a strong feeling that lube will only collect dust/dirt and cause dragging and will require frequent cleaning, but good to check with those who have more knowledge on the matter! Do you run with or without?
Many thanks,
Jason.
