2012 Ossa 280i clutch issue
Posted: Sun Jun 15, 2014 8:53 am
Hi there,
I have recently purchased a 2012 Ossa 280i, it's practically brand new (prev. owner did 90mins on it from new, i've done about 3 hours on it).
I'm new to trials bikes, been riding enduro bikes for the last 6 years.
- the clutch, when you are in neutral and it's running, soon as you click into 1st gear you will take off and start rolling forward, even though the clutch is pulled in all the way. even after its warmed up, you can ride around with the clutch pulled all the way in. so basically its impossible to stop completely and work on balance and ride properly, because the bike wants to go forward even if you don't give any throttle.
As I said i'm new to trials bikes, and i'm sure there are easy fixes to these problems. When the bike is running, i'm having lots of fun, its certainly different to my 250 2stroke KTM. If I can sort the above issues out, it'd be super.
ax
ax
