OSSA MAR Green & Gold Correct Colours.
Posted: Fri Aug 01, 2014 9:25 pm
by Rod
As above, does anyone know of the correct colours for an old MAR mk1. I've only recently discovered the RAL international paint code system since googling "Ossa Green". Pretty sure the resulting codes are for modern day Ossa's and not the old beauties, but can anyone elaborate.
Paint code Ral 6024, also known as 'Traffic Green' came up as the official green and Ral 1024 came up as the pin stripe colour, also known as ocre yellow, but I'm pretty sure this is for modern day Ossa's. Does anyone know if these colours will do justice to an old MAR ?
When I had autobarn mix me up some Ral 6024 green it looked to be too light and peppermint in colour to what I thought it should look like for an old MAR, I then had him darken it slightly to match the side panel I took in as a sample. Problem is I don't know for sure if my sample side panel cover is the correct shade of green either.
I'm a bit pedantic, my MAR was supposedly unrestored but I'm not convinced of that now so I'm not sure if it wears the correct green. If anyone out there has a known unrestored MAR and knows what colours match then please pipe in.
Re: OSSA MAR Green & Gold Correct Colours.
Posted: Sat Aug 02, 2014 8:29 pm
by Rod
Ossa's "Visual Identity Handbook" apparently, this is where I found those RAL codes for anyone that's interested.
http://www.trialsport.se/images/handboo ... or_eng.pdf
