Howdy all..
I have a dumb question (again)
When transporting my bikes I've always used a chock between the front tyre and the under side of the guard.. Problem is, trials bike guards are on the tyre.
How does everyone get around this to save the constant pressure on the forks damaging seals??
Cheers.
Transporting your bike?
Re: Transporting your bike?
I use the Tyre Down http://www.kyaracing.com.au/off_road_tyre_down.htm for off road bikes on my easytrailer 4'x3.5' - 830TAhttp://www.easytrailer.com.au/multifunction_trailers.html fitted with the single motorbike channel. The "tyredowns" work great - stabilise the rear wheel. I then use stabilising tiedowns on the lower fork tubes up front (at front fender level) purely as peace of mind and extra stabilisation but the forks are not under any tension and can move with the bike. Never had a problem using this system for more than 3 years.
Option 1 You can use a kids pneumatic ball that has just the right amount of air so you can fit it between the fork tubes. The ball spreads out on the guard and avoids the damage that a solid chock would cause to the guard
Option 2 Use a solid chock that acts between parts on the bike that are strong enough to withstand the force, ie between the lower triple clamp and the fork slider or axle
I personally don't use anything there myself, do transport my bikes with the front pulled down and don't have any problems with fork seals leaking in transit
Tie the front wheel into the corner. Tie the back wheel to the side of the trailer. Now that both wheels won't bounce around tie the handlebars to the sides where the ties won't slide along. Don't need to compress the forks at all. Bike will sway around but not fall over.
TaffyEvans
- Club: None
- Bike: Harley D
Hi, on local trips around town I don't bother, but on longer trips I put a milk crate under the bash plate. I keep it in place with a ocky strap hooked in one side over the bike and into the other side, or a couple of those short straps through the footpegs.
Cheers Taff
Cheers Taff
- Terryg
Would one of these be any good ? http://www.ebay.com.au/itm/MOTORBIKE-WH ... 259859800b
- BorisTas
- Club: TMTC
- Bike: '12 Cabby , TRL260
They work a treat Grumps , can buy similar at Supercheap for up to half as much on special . $100 now but regularly $60 odd
http://search.supercheapauto.com.au/search?w=Motorcycle%20wheel%20chocks
"I'm all for buying more bikes more often. Why pay off the morgage or save for retirement or stick your money in super, buy bikes and live." {Craypot}
thumper-darryl
- Club: CQTC
- Bike: Beta
Like Cota said, if you can stabilize the rear wheel you need basically nothing on the front wheel.
I use a hitch mount carrier for either my trials bike or the Adv bike. I use a good quality ratchet tie down with carribeners on the ends. Loop the strap around the top of the rear wheel a couple of times and then down to the ratchet portion. Once tightened down there is NO movement of the bike. I throw a couple of tie downs onto the front triple clamps just for show. Even the big bikes do not move an inch.
Last night the ground spoke to me. It said" Do not fear, when you fall I will catch you"
