2014 Gas Gas 250 TXT Pro Tranny leaking oil
Has this ever to anyone? ( oil dripping from the transmission ). Is this some serius issue like tranny crack or just a seal or something?
- The Hell Team
- Dealer
Re: 2014 Gas Gas 250 TXT Pro Tranny leaking oil
What part of the transmission is it "dripping" from?
You probably need to isolate exactly where it is coming from to find the solution. It could be a side case gasket leak, it could be from around the kick start seal or the gear shift seal, or it could be the sump plug drain washer is missing, or the plug is not done up enough.
Try cleaning the engine area very thoroughly, so remove all traces of oil and dirt. Dry the bike off, then try and isolate where the source of the oil is coming from.
The Hell Team Trials Store
02.8424.6400
0418.415.129
[email protected]
http://www.thehellteam.com
02.8424.6400
0418.415.129
[email protected]
I can't really see it it's because it drips very2 little it just accumulates on the bashplate my mechanic said that i put too much oil that's why its' leaking... it's so strange
- The Hell Team
- Dealer
If you cant see it then you may need to use your fingers and try and"feel" for it.
You may need a strong torch and get down on your knees. Feel around the sump plug first. Then run your finger along the seam between side cover and crankcase etc etc. Be methodical, clean and patient and you will find it.
02.8424.6400
0418.415.129
[email protected]
02.8424.6400
0418.415.129
[email protected]
Probably just chain oil or spilt tranny oil? where is the breather from the tranny?
