rust in tank
uk steve
Bike: ty 175
rust in tank
Post by uk steve »
:x rust in my tank can i treat this problem.this came about after the sand blaster never took care and filled the tank with sand when he blasted it then left it out in wet conditon what a f!!!!!!! plonker
if my vans a rocking dont bother knocking! (dont laugh your daughter might be inside) bikes are born to be ridden
I Russ
Bike: KT250,TTR325
Re: rust in tank
Post by I Russ »
Check out the info in twinshock- KT250 resto, it tells you all about tank rust in the KT and how to recoat the inside.
Put an inline filter in if you havnt already,I have one in my KT which has a bit of rust coming through,reverse flush every so often,its never been a problem for me.
Russ
uk steve
Bike: ty 175
Re: rust in tank
Post by uk steve »
thanks russ
motodevo
Re: rust in tank
Post by motodevo »
fill the tank with vinegar to the brim and let it sit for 3 or 4 days, all the rust will be gone. Then always keep it full when you put it away or seal it with a tank sealer like POR15
