Thanks again,
Graham
Folks,
I've been having some "hunting" issues with an '07 Sherco 250 that i bought. So far I have cleaned all fuel tank lines and carby several times, set the float level to 19mm, replaced the crank seal on the flywheel side, and retarded the timing. The bike is running much better since the first ride, but still hunts. I am now looking at replacing the clutch side crankhaft seal. This is where I am now confused as the exploded parts diagram shows the same seal on both sides of the crankshaft on the outside of the bearings and after removing the clutch, there is no seal, just the bearing. The depression where one would expect the seal to sit is a larger diameter (about 1mm larger) and the depth too shallow for the seal to sit. Am I crazy (dont answer that) or is the exploded diagram wrong and the seal on the other side of the bearing?
Your help would be much appreciated. Otherwise my next step is to find a good mechanic to find the issue for me.
Graham Johnston
Trials newby Oakleigh MC
