New from Japan
Tioli
Bike: ty175je , KDX/KX ,,,
Re: New from Japan
Post by Tioli »
Thanks for the tip Ito
I have just the rubber to make grip pads like yours :D
ito
Bike: Beta Techno 1994
Prior to ride
Post by ito »
Prior to ride,I am studying Techno.
As she is my first 2 stroke motorcycle.
I was wondering where I should fill cooling liquid.
Cap of EVO locates top of radiator.
But Techno has no cap at top of radiator.
I found the tank cap locates next to fuel tank cap.
Wow,I have to mix fuel and engine oil by myself.
I thought filling separately and mixed automatically.
Real competition motorcycle!
updated.
coolant liquid.jpg (382.43 KiB) Viewed 45776 times
ito
Received Hydraulic clutch hose from HEL in UK
Post by ito »
I have received the hose from HEL in UK. What a surprise ! It took only 8 days!
ito
Post by ito »
I replaced damaged hose with new one from HEL.
I filled DOT4 but DOT4 did not flow and no air came out.
Spring could have wasted or rubbers for piston could have wasted.
Or cylinder housing could have wasted.
Nevertheless I will replace with complete Hydraulic master cylinder with lever.
BetaTechno hydraulic clutch hose repair.jpg (376.32 KiB) Viewed 43778 times
ito
Alternative hydraulic clutch
Post by ito »
If nesessary,I will buy latest clutch master cylinder for 2015 EVO.
Does it work at Techno ?
ito
Clutch repair
Post by ito »
I decided to overhaul master cylinder.
When opened,rust came.
Umm..
Spring receipt cup stuck at entrance.
ito
Re: New from Japan
Post by ito »
Finally I could get out piston which rust worst.
Piston got rust.jpg (258.45 KiB) Viewed 32904 times
ito
Worn side stand
Post by ito »
Side stand receiving part worn so that body could not stand alone.
I made a aluminum spacer in order to go side stand backward.
It is not bad. When worn again,I will replace it with steel plate.
ito
Hydraulic clutch issue
Post by ito »
I gave up replacing with new seal kit and HEL hose.
Finally I got Chinese master cylinder and hose as shown on picture.
I assembled them onto Beta and filled DOT4 fluid.
Then I found a piece of chain slide block lie down on bumper plate.
Every parts seemed to be worn. Chain tension block is as well.
ito
Gas leaked at petrol cock
Post by ito »
As I finished installation of new clutch system,I filled mixed gasoline to Beta.
But gasoline leaked at on position. I will replace with new petcock for Techno.
