Page 2 of 2
Re: gas gas question.
Posted: Thu Jan 10, 2008 2:19 pm
by Neo
Great news .....where did you buy it from??
Best of balance.
Posted: Thu Jan 10, 2008 6:21 pm
by phoenix75
If you want to get that airbox back together clean the surface with a cleaner then apply either 401 or 406 Loctitie which is industrial strength Super Glue
Posted: Fri Jan 11, 2008 6:55 am
by Neo
phoenix75 wrote:If you want to get that airbox back together clean the surface with a cleaner then apply either 401 or 406 Loctitie which is industrial strength Super Glue
Hmmmm.... now here's a man that knows his glues :wink:
Would that work on an 06 Sherco Tail too?
What type of shop/outlet sells these glues?
Thanks Phoenix.
Best of balance.
Posted: Fri Jan 11, 2008 7:25 am
by yoda
Neo, i got it from autopro, i would imagine repco, supercheap atc would also have it.
Cheers pheonix, if the stuff i used doesn't hold i'll give the loctite a go.
Posted: Fri Jan 11, 2008 8:53 am
by Neo
From the LOCTITE website
Instant Adhesive 401 - Bonding porous materials�
Instant Adhesive 403- Low Odour/Low Bloom Gap Filling�
Instant Adhesive 406 - Difficult to bond plastics and rubbers�
Instant Adhesive 408 - Low Odour, Low Bloom, Low Viscosity�
Instant Adhesive 410 - Toughened, Gap Filling�
Instant Adhesive 454 - Non-drip gel�
Instant Adhesive 460 - Low Odour/Low Bloom for close fitting parts�
Instant Adhesive 480 - Black, toughened�
Instant Adhesive 499 - Thermal Cycling Gel�
Instant Adhesive 4210 - Thermal Resistant�
Instant Adhesive 4212 - Thermal Resistant Gel�
Instant Adhesive 4471 - Surface Insensitive - Gap Filling�
406 looks like it's worth a try to me?
Best of balance.
Posted: Sat Jan 12, 2008 2:41 am
by r2wtrials
Am i getting this wrong... do you mean the top cover and lower black part that contains the filter?.. if so it is screwed together. And you use silkaflex to seal it. The problem with the 02 model pro was that it didn't have enough screws to stop it flexing and leaking but the actual halves were held together with small self taper screws.
Posted: Mon Jan 14, 2008 7:01 am
by yoda
Thats the bit.. Problem is mine is the 02, and a when it broke it pulled the screws through with the piece they were attatched to!
It seems to be holdong ok for the moment tho.
Thanks for the help!
Posted: Mon Jan 14, 2008 12:47 pm
by gasman
I tried getting a broken gg airbox plastic welded together, that lasted about 1 minute. The locktite sounds like the go. I also agree with Drakey buy a scorpa they just don't seem to die.
Posted: Wed Apr 02, 2008 7:31 am
by Neo
Just to let anyone know that 406 Loctitie did the job perfectly on my O6 Sherco Tail.
There is another product call Q-Bond which I got from Repco. And ended up fixing my daughters GG Airbox with.
But Q-Bond comes with some crystals which can be used to support the break your trying to fix. By pouring the crystals on and then dripping the glue on too.
Anyway, I used the Q-Bond crystals with the 406 Loctitie to fix my Sherco tail and it's still holding strong after about 20 rides.....Considering the break is right on the bend of the tail. This is not bad result (406 Loctitie and Q-Bond crystals) , I think =D>
Best of balance.
