Page 1 of 2
Wandering Tyre
Posted: Sun May 17, 2020 6:17 pm
by whitehillbilly
Good Evening.
Have wandering tyre problems on my Greeves.
Ripped another valve, on the front tube.
Rim lock, good quality and correct size, One on the front, two on the back.
Both newish IRC's on original type deep valance, alloy rims.
6 psi on front, 4 on rear.
Must be the 12 hp, the old Villiers motor produces.
Read David L's comments on his post. think it involves reshaping in inside ribs ?
Thanks for any suggestions.
Re: Wandering Tyre
Posted: Mon May 18, 2020 8:40 am
by The Hell Team
Check if the IRC's are tubed type or tubeless (it is written on the side wall). I know the importer in Australia bought in both types.
We only sold the Tube Type at The Hell Team, but there is tubeless ones around and the edge construction is different.
Re: Wandering Tyre
Posted: Mon May 18, 2020 11:39 am
by Jools
I know it's a bit drastic, but back in the day it was not unusual to drill and fit self-tappers around the rim penetrating into the tyre bead. Wouldn't recommend it now though... particularly with 12hp of Villiers volition!
Re: Wandering Tyre
Posted: Mon May 18, 2020 11:46 am
by whitehillbilly
Thanks.
Will look at the Tyre. About to put in new tube.
Think I may have put self tappers in my old James Trials Rims.
Re: Wandering Tyre
Posted: Mon May 18, 2020 6:11 pm
by whitehillbilly
Good Evening.
Update. Tyres tube type.
Gave the rim and bead lock a buff up with small wire wheel on cordless.
New heavy duty Dunlop tube much, much thicker than old one.
Years ago i bought Front/Rear trials tyres with tubes, add was in 'Just Bikes'
$100, free postage for the lot. The tubes were very thin, and I fitted them to the Greeves.
They would have made a great road tyres, and could be used, but to hard for Trials, especially on wet rocks.
They had NO grip, so put IRC tyres on. May have used old tubes.
Anyway all done. Will keep an eye on the valve movement.
Thanks.
Re: Wandering Tyre
Posted: Mon May 18, 2020 6:23 pm
by Jools
An' if you get sick of the ol' Greeves........
Re: Wandering Tyre
Posted: Mon May 18, 2020 9:21 pm
by Guy53
Wow. That vintage bike sure have great front brake.
Re: Wandering Tyre
Posted: Mon May 18, 2020 10:07 pm
by Jools
Huh!!!
Guy... You should have been there when this was THE LATEST THING! Talk about Hi tech.
Cast aluminium front downtube?... leading link front suspension?...
A bloke in our village had one, and I was a transfixed 13 year old every time it passed me!
(Then I discovered Jack Kerouac and girls!!!
Downhill all the way from there!
Re: Wandering Tyre
Posted: Tue May 19, 2020 6:56 am
by whitehillbilly
Hi Guy,
Added to Villiers Services, soft compound trials shoes, stops real good, even when wet.
Re: Wandering Tyre
Posted: Tue May 19, 2020 8:13 am
by Gomey
What lubricant are you putting the tyres in the rims with? Sometimes if it too slippery and you don’t clean it off nothing will stop the tyre spinning in rim.
