Gas Gas 1999 TXT 270 oil filler - where is it?
Posted: Wed Jan 05, 2011 12:44 pm
by keithj
From a community member:
"How and where is the oil filler on the 1999 270 txt gasgas,we have been taking off the cluch case to fill it.Just can not seem to see a oil filler hole/plug? any help will be great ,it's a pain doing it the way were doing it now."
Can anyone locate it on this pic?
Re: Gas Gas 1999 TXT 270 oil filler - where is it?
Posted: Wed Jan 05, 2011 8:26 pm
by Gary B
I had a '99 Gasser but sorry I can't remember.
But, more importantley I don't remember it being a pain in the bum to change the gearbox oil, I certainley never took the clutch cover off when I had it.
I'd be calling the Gas Gas Guru from back then who is Mal Loone.
I'm sure his photographic memeory will be able to help you out.
Posted: Wed Jan 05, 2011 8:40 pm
by Gary B
Just had a look at a '99 parts manual on the interweb thingy & its shows an "Oil Plug" just above & more horizontal than the kickstarter. It should have a copper washer under the oil filler plug.
Posted: Wed Jan 05, 2011 10:59 pm
by The Hell Team
Gary is correct it is just near the kickstart on the right side case.
Please see attached pic. It's item #9.
Posted: Fri Jan 07, 2011 7:02 am
by bigdog
Hi,thanks for your reply's.I still can not seem to find that filler.I have taken a few photo's to show and if it was above kick starter on crank case would be under mid-chamber and I can not see one on outer cluch case
