TY 175 stator check electric's?
Posted: Tue Aug 12, 2014 10:48 am
by mik60ish
Hi I hope David Lahey can help me out I've just bought anther TY 175 it hasn't been run for appx 20 years hence no spark I checked coil on my other 175 its OK I have pulled the stator out how do I do tests to see whats wrong, while its out was going to disconnect the the 2 wires for the lights etc, And leave 1 black lead for ignition.
Re: TY 175 stator check electric's?
Posted: Tue Aug 12, 2014 12:55 pm
Mike, like any points coil ignition system, the stator winding should have a lowish resistance measured from end to end. Can't remember the correct number of ohms. Too low and it might be shorting to earth, too high and the winding has a break.
The usual problem on TY175 coils is corrosion and/or breakage where the coil winding joins the insulated cable. You can usually unwind a turn off the winding and make a fresh solder joint to join to a new piece of cable. Make sure you use something to hold the rest of the winding to keep it from coming loose, but without damaging the lacquer coating. Slip a piece of "spaghetti" or some heat shrink over any exposed copper. Electricians will probably shudder, but I fasten the end of the remaining coil winding in place with a small plastic cable tie around the winding
You can take the stator coil for the lights off the stator plate and leave it off. It makes no difference to the ignition
Posted: Tue Aug 12, 2014 6:40 pm
by TriCub
Have you tried cleaning the pionts? If it's been sitting for 20 years the pionts will have corroded.
Posted: Wed Aug 20, 2014 10:18 am
by mik60ish
Hi David I didn't understand your remedy! What I did was take the stator from my other TY which had a good spark fitted it to 2nd bike still no spark, removed fitted it back to 1st bike now no spark do the points need resetting. I tried setting points on both bikes but I canny see will have to someone with younger eyes!
Posted: Thu Aug 21, 2014 10:59 am
by TriCub
Just been into the TY factory shop manual looking up a clearance and found the resistance specs you wanted.
Primary winding 4.5 ohms +- 10%. Secondary winding 6.0k ohms +- 20%.
